[GRASSLIST:1042] Re: gdal problem
    Keith J. Forbes
    listsemail at gmx.net
    Wed Aug 27 10:33:37 EDT 2003
should have added that I am using Redhat 9.0 (GNU/Linux)
On Wednesday 27 August 2003 03:19 pm, Keith J. Forbes wrote:
> Hi. I am trying to import what I am pretty sure is an Arcinfo binary grid
> formatted file. The file was created from a grid of points in Arcview using
> the inverse distance weighting method. Specifically the command from
> Arcview was Theme|Convert to Grid. The file name is w001001x.adf.
> I installed Grass from sources but recall having difficulties installing
> gdal. I don't recall if I ever installed it or not. The only folder I have
> with gdal is the following:
> (/usr/local/share/gdal)
> [keith at siam1 gdal]$ ls -al
> total 568
> drwxr-xr-x    2 root     root         4096 Jun  6 13:20 .
> drwxr-xr-x   15 root     root         4096 Jul 22 17:20 ..
> -rw-r--r--    1 root     root        73770 Jun  6 13:20 datum.csv
> -rw-r--r--    1 root     root        10735 Jun  6 13:20 ellipsoid.csv
> -rw-r--r--    1 root     root        22351 Jun  6 13:20 gcs.csv
> -rw-r--r--    1 root     root          533 Jun  6 13:20 gdalicon.png
> -rw-r--r--    1 root     root       332781 Jun  6 13:20 pcs.csv
> -rw-r--r--    1 root     root         1599 Jun  6 13:20 prime_meridian.csv
> -rw-r--r--    1 root     root         7254 Jun  6 13:20 s57attributes.csv
> -rw-r--r--    1 root     root        20885 Jun  6 13:20
> s57expectedinput.csv -rw-r--r--    1 root     root        30680 Jun  6
> 13:20 s57objectclasses.csv -rw-r--r--    1 root     root         9216 Jun
> 6 13:20 seed_2d.dgn -rw-r--r--    1 root     root        10315 Jun  6 13:20
> stateplane.csv -rw-r--r--    1 root     root        15266 Jun  6 13:20
> unit_of_measure.csv
> When I run r.in.gdal (accepting all defaults), I always get "Segmentation
> fault" as an error.
> QUESTIONS:
> Do I need to reinstall gdal? If not, why are my attempts at importing
> arcinfo binary grids (w001001x.adf) not working. Would appreciate any help.
> Thanks in advance,
> Keith
> ........what happens when I run r.in.gdal....................
> GRASS:/usr/local/share/applications > r.in.gdal
> OPTION:   Bin raster file to be imported
>      key: input
> required: YES
> enter option > /home/keith/grass5/datasrc/hadrm/a2c_con/etp/w001001x.adf
> You have chosen:
>   input=/home/keith/grass5/datasrc/hadrm/a2c_con/etp/w001001x.adf
> Is this correct? (y/n) [y]
> OPTION:   Band to select (default is all bands)
>      key: band
> required: NO
> enter option >
> OPTION:   Name for resultant raster map
>      key: output
> required: YES
> Enter raster file name
> Enter 'list' for a list of existing raster files
> Hit RETURN to cancel request
> > testadf
> <testadf>
> OPTION:   Name of location to read projection from for GCPs transformation
>      key: target
> required: NO
> enter option >
> OPTION:   Title for resultant raster map
>      key: title
>   format: "phrase"
> required: NO
> enter option >
> OPTION:   Name for new location to create
>      key: location
> required: NO
> enter option >
> FLAG: Set the following flag?
>     Override projection (use locations projection)?(y/n) [n]
>     Extend location extents based on new dataset.?(y/n) [n]
> Segmentation fault
k|J|f
