[GRASSLIST:1041] gdal problem
Keith J. Forbes
listsemail at gmx.net
Wed Aug 27 10:19:59 EDT 2003
Hi. I am trying to import what I am pretty sure is an Arcinfo binary grid
formatted file. The file was created from a grid of points in Arcview using
the inverse distance weighting method. Specifically the command from Arcview
was Theme|Convert to Grid. The file name is w001001x.adf.
I installed Grass from sources but recall having difficulties installing gdal.
I don't recall if I ever installed it or not. The only folder I have with
gdal is the following:
(/usr/local/share/gdal)
[keith at siam1 gdal]$ ls -al
total 568
drwxr-xr-x 2 root root 4096 Jun 6 13:20 .
drwxr-xr-x 15 root root 4096 Jul 22 17:20 ..
-rw-r--r-- 1 root root 73770 Jun 6 13:20 datum.csv
-rw-r--r-- 1 root root 10735 Jun 6 13:20 ellipsoid.csv
-rw-r--r-- 1 root root 22351 Jun 6 13:20 gcs.csv
-rw-r--r-- 1 root root 533 Jun 6 13:20 gdalicon.png
-rw-r--r-- 1 root root 332781 Jun 6 13:20 pcs.csv
-rw-r--r-- 1 root root 1599 Jun 6 13:20 prime_meridian.csv
-rw-r--r-- 1 root root 7254 Jun 6 13:20 s57attributes.csv
-rw-r--r-- 1 root root 20885 Jun 6 13:20 s57expectedinput.csv
-rw-r--r-- 1 root root 30680 Jun 6 13:20 s57objectclasses.csv
-rw-r--r-- 1 root root 9216 Jun 6 13:20 seed_2d.dgn
-rw-r--r-- 1 root root 10315 Jun 6 13:20 stateplane.csv
-rw-r--r-- 1 root root 15266 Jun 6 13:20 unit_of_measure.csv
When I run r.in.gdal (accepting all defaults), I always get "Segmentation
fault" as an error.
QUESTIONS:
Do I need to reinstall gdal? If not, why are my attempts at importing arcinfo
binary grids (w001001x.adf) not working. Would appreciate any help.
Thanks in advance,
Keith
........what happens when I run r.in.gdal....................
GRASS:/usr/local/share/applications > r.in.gdal
OPTION: Bin raster file to be imported
key: input
required: YES
enter option > /home/keith/grass5/datasrc/hadrm/a2c_con/etp/w001001x.adf
You have chosen:
input=/home/keith/grass5/datasrc/hadrm/a2c_con/etp/w001001x.adf
Is this correct? (y/n) [y]
OPTION: Band to select (default is all bands)
key: band
required: NO
enter option >
OPTION: Name for resultant raster map
key: output
required: YES
Enter raster file name
Enter 'list' for a list of existing raster files
Hit RETURN to cancel request
> testadf
<testadf>
OPTION: Name of location to read projection from for GCPs transformation
key: target
required: NO
enter option >
OPTION: Title for resultant raster map
key: title
format: "phrase"
required: NO
enter option >
OPTION: Name for new location to create
key: location
required: NO
enter option >
FLAG: Set the following flag?
Override projection (use locations projection)?(y/n) [n]
Extend location extents based on new dataset.?(y/n) [n]
Segmentation fault
k|J|f
