[GRASSLIST:1045] Re: gdal problem
Daniel Victoria
daniel_victoria at yahoo.com
Wed Aug 27 11:54:54 EDT 2003
Keith,
>From what I remember, Arc grids are directories with
some files in it and also there are some files that
belong to the grid inside a folder called info so,
just one file will not do the trick
Have you tried running gdal on the directory instead
of one file? Something like this:
r.in.gdal /home/keith/grass5/datasrc/hadrm/a2c_con/etp
Just my 2 cents...
Daniel
--- "Keith J. Forbes" <listsemail at gmx.net> wrote:
> Hi. I am trying to import what I am pretty sure is
> an Arcinfo binary grid
> formatted file. The file was created from a grid of
> points in Arcview using
> the inverse distance weighting method. Specifically
> the command from Arcview
> was Theme|Convert to Grid. The file name is
> w001001x.adf.
> I installed Grass from sources but recall having
> difficulties installing gdal.
> I don't recall if I ever installed it or not. The
> only folder I have with
> gdal is the following:
> (/usr/local/share/gdal)
> [keith at siam1 gdal]$ ls -al
> total 568
> drwxr-xr-x 2 root root 4096 Jun 6
> 13:20 .
> drwxr-xr-x 15 root root 4096 Jul 22
> 17:20 ..
> -rw-r--r-- 1 root root 73770 Jun 6
> 13:20 datum.csv
> -rw-r--r-- 1 root root 10735 Jun 6
> 13:20 ellipsoid.csv
> -rw-r--r-- 1 root root 22351 Jun 6
> 13:20 gcs.csv
> -rw-r--r-- 1 root root 533 Jun 6
> 13:20 gdalicon.png
> -rw-r--r-- 1 root root 332781 Jun 6
> 13:20 pcs.csv
> -rw-r--r-- 1 root root 1599 Jun 6
> 13:20 prime_meridian.csv
> -rw-r--r-- 1 root root 7254 Jun 6
> 13:20 s57attributes.csv
> -rw-r--r-- 1 root root 20885 Jun 6
> 13:20 s57expectedinput.csv
> -rw-r--r-- 1 root root 30680 Jun 6
> 13:20 s57objectclasses.csv
> -rw-r--r-- 1 root root 9216 Jun 6
> 13:20 seed_2d.dgn
> -rw-r--r-- 1 root root 10315 Jun 6
> 13:20 stateplane.csv
> -rw-r--r-- 1 root root 15266 Jun 6
> 13:20 unit_of_measure.csv
> When I run r.in.gdal (accepting all defaults), I
> always get "Segmentation
> fault" as an error.
> QUESTIONS:
> Do I need to reinstall gdal? If not, why are my
> attempts at importing arcinfo
> binary grids (w001001x.adf) not working. Would
> appreciate any help.
> Thanks in advance,
> Keith
> ........what happens when I run
> r.in.gdal....................
> GRASS:/usr/local/share/applications > r.in.gdal
> OPTION: Bin raster file to be imported
> key: input
> required: YES
> enter option >
/home/keith/grass5/datasrc/hadrm/a2c_con/etp/w001001x.adf
> You have chosen:
input=/home/keith/grass5/datasrc/hadrm/a2c_con/etp/w001001x.adf
> Is this correct? (y/n) [y]
> OPTION: Band to select (default is all bands)
> key: band
> required: NO
> enter option >
> OPTION: Name for resultant raster map
> key: output
> required: YES
> Enter raster file name
> Enter 'list' for a list of existing raster files
> Hit RETURN to cancel request
> > testadf
> <testadf>
> OPTION: Name of location to read projection from
> for GCPs transformation
> key: target
> required: NO
> enter option >
> OPTION: Title for resultant raster map
> key: title
> format: "phrase"
> required: NO
> enter option >
> OPTION: Name for new location to create
> key: location
> required: NO
> enter option >
> FLAG: Set the following flag?
> Override projection (use locations
> projection)?(y/n) [n]
> Extend location extents based on new
> dataset.?(y/n) [n]
> Segmentation fault
> k|J|f
__________________________________
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
http://sitebuilder.yahoo.com
