[GRASSLIST:1047] Re: gdal problem
Keith J. Forbes
listsemail at gmx.net
Wed Aug 27 12:07:05 EDT 2003
Thanks Daniel. Tried your suggestion and ...
GRASS:~/grass5/datasrc/hadrm/a2c_con/tmed > r.in.gdal input=~/grass5/datasrc/hadrm/a2c_con/etp output=etp
Segmentation fault
Anyone has any ideas?
Keith
On Wednesday 27 August 2003 04:54 pm, Daniel Victoria wrote:
> Keith,
> From what I remember, Arc grids are directories with
> some files in it and also there are some files that
> belong to the grid inside a folder called info so,
> just one file will not do the trick
> Have you tried running gdal on the directory instead
> of one file? Something like this:
> r.in.gdal /home/keith/grass5/datasrc/hadrm/a2c_con/etp
> Just my 2 cents...
> Daniel
> --- "Keith J. Forbes" <listsemail at gmx.net> wrote:
> > Hi. I am trying to import what I am pretty sure is
> > an Arcinfo binary grid
> > formatted file. The file was created from a grid of
> > points in Arcview using
> > the inverse distance weighting method. Specifically
> > the command from Arcview
> > was Theme|Convert to Grid. The file name is
> > w001001x.adf.
> > I installed Grass from sources but recall having
> > difficulties installing gdal.
> > I don't recall if I ever installed it or not. The
> > only folder I have with
> > gdal is the following:
> > (/usr/local/share/gdal)
> > [keith at siam1 gdal]$ ls -al
> > total 568
> > drwxr-xr-x 2 root root 4096 Jun 6
> > 13:20 .
> > drwxr-xr-x 15 root root 4096 Jul 22
> > 17:20 ..
> > -rw-r--r-- 1 root root 73770 Jun 6
> > 13:20 datum.csv
> > -rw-r--r-- 1 root root 10735 Jun 6
> > 13:20 ellipsoid.csv
> > -rw-r--r-- 1 root root 22351 Jun 6
> > 13:20 gcs.csv
> > -rw-r--r-- 1 root root 533 Jun 6
> > 13:20 gdalicon.png
> > -rw-r--r-- 1 root root 332781 Jun 6
> > 13:20 pcs.csv
> > -rw-r--r-- 1 root root 1599 Jun 6
> > 13:20 prime_meridian.csv
> > -rw-r--r-- 1 root root 7254 Jun 6
> > 13:20 s57attributes.csv
> > -rw-r--r-- 1 root root 20885 Jun 6
> > 13:20 s57expectedinput.csv
> > -rw-r--r-- 1 root root 30680 Jun 6
> > 13:20 s57objectclasses.csv
> > -rw-r--r-- 1 root root 9216 Jun 6
> > 13:20 seed_2d.dgn
> > -rw-r--r-- 1 root root 10315 Jun 6
> > 13:20 stateplane.csv
> > -rw-r--r-- 1 root root 15266 Jun 6
> > 13:20 unit_of_measure.csv
> > When I run r.in.gdal (accepting all defaults), I
> > always get "Segmentation
> > fault" as an error.
> > QUESTIONS:
> > Do I need to reinstall gdal? If not, why are my
> > attempts at importing arcinfo
> > binary grids (w001001x.adf) not working. Would
> > appreciate any help.
> > Thanks in advance,
> > Keith
> > ........what happens when I run
> > r.in.gdal....................
> > GRASS:/usr/local/share/applications > r.in.gdal
> > OPTION: Bin raster file to be imported
> > key: input
> > required: YES
> > enter option >
> /home/keith/grass5/datasrc/hadrm/a2c_con/etp/w001001x.adf
> > You have chosen:
> input=/home/keith/grass5/datasrc/hadrm/a2c_con/etp/w001001x.adf
> > Is this correct? (y/n) [y]
> > OPTION: Band to select (default is all bands)
> > key: band
> > required: NO
> > enter option >
> > OPTION: Name for resultant raster map
> > key: output
> > required: YES
> > Enter raster file name
> > Enter 'list' for a list of existing raster files
> > Hit RETURN to cancel request
> > > testadf
> > <testadf>
> > OPTION: Name of location to read projection from
> > for GCPs transformation
> > key: target
> > required: NO
> > enter option >
> > OPTION: Title for resultant raster map
> > key: title
> > format: "phrase"
> > required: NO
> > enter option >
> > OPTION: Name for new location to create
> > key: location
> > required: NO
> > enter option >
> > FLAG: Set the following flag?
> > Override projection (use locations
> > projection)?(y/n) [n]
> > Extend location extents based on new
> > dataset.?(y/n) [n]
> > Segmentation fault
> > k|J|f
> __________________________________
> Do you Yahoo!?
> Yahoo! SiteBuilder - Free, easy-to-use web site design software
> http://sitebuilder.yahoo.com
k|J|f
