[GRASSLIST:1050] Re: gdal problem
    Daniel Victoria
    daniel_victoria at yahoo.com
    Wed Aug 27 12:43:37 EDT 2003
Keith,
I just read gdal page and it says:
"The projections support (read if a prj.adf file is
available) is quite limited. "
Maybee that's the problem? Is your grid projected?
--- "Keith J. Forbes" <listsemail at gmx.net> wrote:
> Thanks Daniel. Tried your suggestion and ...
> GRASS:~/grass5/datasrc/hadrm/a2c_con/tmed >
> r.in.gdal input=~/grass5/datasrc/hadrm/a2c_con/etp
> output=etp
> Segmentation fault
> Anyone has any ideas?
> Keith
> On Wednesday 27 August 2003 04:54 pm, Daniel
> Victoria wrote:
> > Keith,
> > From what I remember, Arc grids are directories
> with
> > some files in it and also there are some files
> that
> > belong to the grid inside a folder called info so,
> > just one file will not do the trick
> > Have you tried running gdal on the directory
> instead
> > of one file? Something like this:
> > r.in.gdal
> /home/keith/grass5/datasrc/hadrm/a2c_con/etp
> > Just my 2 cents...
> > Daniel
> > > Hi. I am trying to import what I am pretty sure
> is
> > > an Arcinfo binary grid
> > > formatted file. The file was created from a grid
> of
> > > points in Arcview using
> > > the inverse distance weighting method.
> Specifically
> > > the command from Arcview
> > > was Theme|Convert to Grid. The file name is
> > > w001001x.adf.
> > > I installed Grass from sources but recall having
> > > difficulties installing gdal.
> > > I don't recall if I ever installed it or not.
> The
> > > only folder I have with
> > > gdal is the following:
> > > (/usr/local/share/gdal)
> > > [keith at siam1 gdal]$ ls -al
> > > total 568
> > > drwxr-xr-x    2 root     root         4096 Jun
> 6
> > > 13:20 .
> > > drwxr-xr-x   15 root     root         4096 Jul
> 22
> > > 17:20 ..
> > > -rw-r--r--    1 root     root        73770 Jun
> 6
> > > 13:20 datum.csv
> > > -rw-r--r--    1 root     root        10735 Jun
> 6
> > > 13:20 ellipsoid.csv
> > > -rw-r--r--    1 root     root        22351 Jun
> 6
> > > 13:20 gcs.csv
> > > -rw-r--r--    1 root     root          533 Jun
> 6
> > > 13:20 gdalicon.png
> > > -rw-r--r--    1 root     root       332781 Jun
> 6
> > > 13:20 pcs.csv
> > > -rw-r--r--    1 root     root         1599 Jun
> 6
> > > 13:20 prime_meridian.csv
> > > -rw-r--r--    1 root     root         7254 Jun
> 6
> > > 13:20 s57attributes.csv
> > > -rw-r--r--    1 root     root        20885 Jun
> 6
> > > 13:20 s57expectedinput.csv
> > > -rw-r--r--    1 root     root        30680 Jun
> 6
> > > 13:20 s57objectclasses.csv
> > > -rw-r--r--    1 root     root         9216 Jun
> 6
> > > 13:20 seed_2d.dgn
> > > -rw-r--r--    1 root     root        10315 Jun
> 6
> > > 13:20 stateplane.csv
> > > -rw-r--r--    1 root     root        15266 Jun
> 6
> > > 13:20 unit_of_measure.csv
> > > When I run r.in.gdal (accepting all defaults), I
> > > always get "Segmentation
> > > fault" as an error.
> > > QUESTIONS:
> > > Do I need to reinstall gdal? If not, why are my
> > > attempts at importing arcinfo
> > > binary grids (w001001x.adf) not working. Would
> > > appreciate any help.
> > > Thanks in advance,
> > > Keith
> > > ........what happens when I run
> > > r.in.gdal....................
> > > GRASS:/usr/local/share/applications > r.in.gdal
> > > OPTION:   Bin raster file to be imported
> > >      key: input
> > > required: YES
> > > enter option >
/home/keith/grass5/datasrc/hadrm/a2c_con/etp/w001001x.adf
> > > You have chosen:
input=/home/keith/grass5/datasrc/hadrm/a2c_con/etp/w001001x.adf
> > > Is this correct? (y/n) [y]
> > > OPTION:   Band to select (default is all bands)
> > >      key: band
> > > required: NO
> > > enter option >
> > > OPTION:   Name for resultant raster map
> > >      key: output
> > > required: YES
> > > Enter raster file name
> > > Enter 'list' for a list of existing raster files
> > > Hit RETURN to cancel request
> > > > testadf
> > > <testadf>
> > > OPTION:   Name of location to read projection
> from
> > > for GCPs transformation
> > >      key: target
> > > required: NO
> > > enter option >
> > > OPTION:   Title for resultant raster map
> > >      key: title
> > >   format: "phrase"
> > > required: NO
> > > enter option >
> > > OPTION:   Name for new location to create
> > >      key: location
> > > required: NO
> > > enter option >
> > > FLAG: Set the following flag?
> > >     Override projection (use locations
> > > projection)?(y/n) [n]
> > >     Extend location extents based on new
> > > dataset.?(y/n) [n]
> > > Segmentation fault
> > > k|J|f
> > __________________________________
> > Do you Yahoo!?
> > Yahoo! SiteBuilder - Free, easy-to-use web site
> design software
> > http://sitebuilder.yahoo.com
> k|J|f
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
