[GRASSLIST:1070] Re: Finding area where sit points without PostgreSQL
tlaronde at polynum.org tlaronde at polynum.org
Fri Aug 29 02:57:11 EDT 2003
En réponse à Radim Blazek <blazek at itc.it>:
> On Wednesday 27 August 2003 18:19, tlaronde at polynum.org wrote:
> > Hello,
> > I have a vectorial map with text which insertion point is inside the
> area
> > it should be associated with. I have used PostgreSQL geometric
> extensions
> > to find where the point (insertion) is in ( '(x,y)' @ boundary ). But
> > 1) I would prefer to use the geometric/topological tool, i.e. GRASS,
> to do
> > this kind of things, and not use database extensions ;
> > Is there a way to do it automatically (batch) in GRASS.
> > Alternate: has someone tips to make it work correctly under PostgreSQl
> To find area the point is within?
> 5.0: v.what (attention to current region!)
> 5.1: v.distance max=0
Thanks! Works simply great!
