[GRASSLIST:1924] (no subject)
leo.lami at katamail.com leo.lami at katamail.com
Mon Dec 1 09:02:38 EST 2003
Thank you very much.
I resolved the problem writing v.digit from
command line putting "d.rast map=***" in
brackets after the option bgcmd=.
It does not work from GUI.
Good work
Leonardo Lami
> Da: Radim Blazek <blazek at itc.it>
> Data: Mon, 1 Dec 2003 14:46:24 +0100
> A: "leo.lami at katamail.com"
<leo.lami at katamail.com>, GRASSLIST at baylor.edu
> Oggetto: Re: [GRASSLIST:1920] v.digit grass5.7
> On Monday 01 December 2003 13:34,
leo.lami at katamail.com wrote:
> > I have a problem with v.digit in grass 5.7.
> > v.digit works well but I cannot to display a
> > raster map in background.
> > When i write "d.rast map=***" in the
background
> > command line of the v.digit window the
output
> > display say: map does not exist
> > It refers to raster map but the raster map
> > exists.
> > Can someone help me?
> Do you run the v.digit from GUI (TclTk) or
command line?
> I think that GUI does not work well if
parameters have spaces.
> Try also to add d.rast later in v.digit
dialog.
> Radim
