[GRASSLIST:1962] Re: (DY)LD_LIBRARY_PATH
Radim Blazek blazek at itc.it
Fri Dec 5 11:41:42 EST 2003
On Friday 05 December 2003 15:35, Christopher Fonnesbeck wrote:
> Can anyone tell me how to change LD_LIBRARY_PATH to DYLD_LIBRARY_PATH
> globally? Even though the configuration file says:
> LD_LIBRARY_PATH_VAR="DYLD_LIBRARY_PATH"
> under the definition for Darwin-*, I still get the following:
> cd OBJ.powerpc-apple-darwin7.0.0;
> LD_LIBRARY_PATH=:/usr/local/src/grass57_exp_2003_11_22/dist.powerpc-
> apple-darwin7.0.0/lib ./test
> ERROR in read/write portable short, byte_order = 0
>    Written: -32768
>    Read   : 0
>    Written: -12345
>    Read   : -57
>    Written: 12345
>    Read   : 57
>    Written: 32767
>    Read   : -1
> make[3]: *** [OBJ.powerpc-apple-darwin7.0.0/test] Error 1
> make[2]: *** [subdirs] Error 1
> make[1]: *** [subdirs] Error 1
> make: *** [default] Error 1
> notice that its NOT using DYLD_LIBRARY_PATH as it is supposed to.
> Thanks,
This was fixed 28.11.2003 in cvs.
Radim
