[GRASSLIST:1982] error with gdal
hamdi ines hamdi_ines2003 at yahoo.fr
Mon Dec 8 05:54:10 EST 2003
Hello,
I m download gdal-cvs-031203 to read gml file in
grass57,but when i execute the command make (after
./configure) the result is:
>make[2]: Entre dans le répertoire
`/home/versionfinaledocgrass57/versionsforopenevfw-gdal/gdal-cvs-031203/frmts/png'
make[2]: Rien à faire pour `install-obj'.
make[2]: Quitte le répertoire
make -C grass install-obj
`/home/versionfinaledocgrass57/versionsforopenevfw-gdal/gdal-cvs-031203/frmts/grass'
/bin/sh ../../libtool --mode=compile g++ -I../../port
-I../../gcore -I../../ogr -Wall  -O2   -c -o
../o/grassdataset.o grassdataset.cpp
 g++ -I../../port -I../../gcore -I../../ogr -Wall -O2
-c grassdataset.cpp  -fPIC -DPIC -o
../o/.libs/grassdataset.o
grassdataset.cpp: In static member function `static
GDALDataset*
   GRASSDataset::Open(GDALOpenInfo*)':
grassdataset.cpp:513: invalid conversion from `int
(*)(...)' to `int (*)()'
make[2]: *** [../o/grassdataset.o] Erreur 1
make[1]: *** [grass-install-obj] Erreur 2
make[1]: Quitte le répertoire
`/home/versionfinaledocgrass57/versionsforopenevfw-gdal/gdal-cvs-031203/frmts'
>make: *** [frmts-target] Erreur 2.
My question is how resolv the error to install gdal
succeffuly.And why when i use the ogr2ogr command in
grass57 it displayes me:
>ogr2ogr -f GML chess.gml
/home/versionfinaledocgrass57/gmlfile/allgmltest
FAILURE:
>Unable to open datasource
`/home/versionfinaledocgrass57/gmlfile/allgmltest'
with the following drivers.
  -> ESRI Shapefile
  -> UK .NTF
  -> SDTS
  -> TIGER
  -> IHO S-57 (ENC)
  -> MapInfo File
  -> DGN
  -> GML
  -> AVCBin
thank you
HAMDI INES
____________________________________________________________________________________
Do You Yahoo!? -- Avec Yahoo! soyez au coeur de la récolte de dons pour le Téléthon.
http://fr.promotions.yahoo.com/caritatif/
