[GRASSLIST:2013] Re: input format of v.net.path in GRASS5.7
    Hayashi Shin-ichiro
    forest at bres.tsukuba.ac.jp
    Wed Dec 10 10:39:40 EST 2003
Dear GRASS users:
Thank you very much for your advise, Radim.
I tried
$ v.net input=walk output=walk_ca
1)My question
1. does v.net give category for all arc and node?
2. Is category number which 1 is arc and 2 is node?
I executed v.net.path. Command worked but didn't make any shortest path.
$ echo "1 5" |v.net.path input=walk_ca output=walkpath
Error messege
WARNING: 54667 points without category.
WARNING: No point with category 1
WARNING: No point with category 5
And I tried
$ v.category in=walk out=walk_ca option=add
I have same question.
1. does v.category give category for all arc and node?
Then I executed v.net.path. Command worked but didn't make any shortest path.
GRASS gives me same error messege.
I execute d.what.rast. But command tell me only infomation about arc.
2)My question
What way can I get infomation about node?
My big question is
What way can I give category number for node?
Please give me your suggestion.
Thank you in advance.
Sincerely yours.
>Nodes on the network are identified by category number of points
>placed exactly on network nodes (ends of lines). If you have lines
>only in you vector, you can add new points by v.net and assign categories
>to points by v.category field=2. Then use these categories as input for v.net:
>echo "1 5" | v.net.path
>Radim
Hayashi Shin-ichiro
mail:forest at bres.tsukuba.ac.jp URL:http://ryuiki.agbi.tsukuba.ac.jp/~forest
Watershed Management Lab., University of TSUKUBA
