[GRASSLIST:2063] Re: [GRASS5] Mac OSX binary install directions
Christopher Fonnesbeck chris at fonnesbeck.org
Tue Dec 16 10:11:53 EST 2003
I'm using AquaR version 1.8 from within both versions 5.0.2 (OpenOSX)
and 5.7 (CVS). It works perfectly simply by calling /usr/local/bin/R
from within GRASS, although when I try and run system() commands from
within GRASS 5.7 I get iconv library version mismatch errors:
 > system("g.list rast")
dyld: g.list version mismatch for library:
/usr/local/lib/libiconv.2.dylib (compatibility version of user: 5.0.0
greater than library's version: 4.0.0)
C.
On Dec 16, 2003, at 8:01 AM, Thomas Adams wrote:
> Hamish,
> I have done this, but how does one invoke the "Aqua R" from within
> GRASS using the 'StartR' application?
> Tom
> Hamish wrote:
> [Setting up GRASS on Mac OSX]
> 3) Install R-statistics[2]
> This is optional, but useful for geostats. Click on CRAN, choose a
> mirror, click on R Binaries, macosx, and download RAqua.dmg. Double
> click on that package and install tcltk, libreadline, and finally
> RAqua. This installs the OSX port of R to Applications/StartR.
> Why did you not install from fink?
> This is not at all a criticism, but rather a legitimate query.
> Two reasons:
> a) I figured the R team had already gone to the trouble to Aqua-fy it,
> and the "offical" port would be better supported and more
> Mac-integrated.
> b) The r-base package isn't yet present in either Fink's stable or
> unstable "current-10.3" branch.
> I still think the Fink project is brilliant though.
> It has been my experience that one of the major sources of confusion
> with OSX is that there are several options for installing unix
> software (and the fact that some of them work better for particular
> packages than others).
> Welcome to the wonderful world of UNIX-powered. Confusing versions of
> the same thing for over 30 years. Still, I'd rather have 3 chances of
> finding a version that does exactly what I want versus 1 generic
> version
> that only partially does. That doesn't mean you can't put together an
> intergrated package with the components pre-chosen by an expert of
> course.
> And if you think the tyranny of choice is bad on OSX, you should give
> Linux a try... eg:
> [Debian]$ apt-cache search editor | wc -l
>     384
> regards,
> Hamish
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
> Thomas E Adams
> National Weather Service
> Ohio River Forecast Center
> 1901 South State Route 134
> Wilmington, OH 45177
> EMAIL:  thomas.adams at noaa.gov
> VOICE:  937-383-0528
> FAX:    937-383-0033
Christopher J. Fonnesbeck ( c h r i s @ f o n n e s b e c k . o r g )
Georgia Cooperative Fish & Wildlife Research Unit, University of Georgia
Name: not available
Type: text/enriched
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20031216/f9101b86/attachment.bin
