[GRASSLIST:2064] error in compiling 5.7 with cxx support on OSX
    Christopher Fonnesbeck
    chris at fonnesbeck.org
    Tue Dec 16 14:51:59 EST 2003
Specifying c++ support in the configuration file results in the
following build errors:
c++ -c -I./IOStream/include -DUSER=\"chris\" -DNODATA_FIX
-D_FILE_OFFSET_BITS=64 -I/usr/local/src/grass57_exp_2003_11_22/include
-DELEV_FLOAT main.cc -o OBJ.powerpc-apple-darwin7.0.0/FLOAT/main.o
-DELEV_FLOAT common.cc -o OBJ.powerpc-apple-darwin7.0.0/FLOAT/common.o
-DELEV_FLOAT stats.cc -o OBJ.powerpc-apple-darwin7.0.0/FLOAT/stats.o
-DELEV_FLOAT fill.cc -o OBJ.powerpc-apple-darwin7.0.0/FLOAT/fill.o
IOStream/include/ami_sort_impl.h: In function `queue<char*>*
    runFormation(AMI_STREAM<T>*, Compare*) [with T = plateauType,
Compare =
    ijCmpPlateauType]':
IOStream/include/ami_sort.h:123:   instantiated from `AMI_err
AMI_sort(AMI_STREAM<T>*, AMI_STREAM<T>**, Compare*, int) [with T =
plateauType, Compare = ijCmpPlateauType]'
sortutils.h:105:   instantiated from `AMI_STREAM<T>*
sort(AMI_STREAM<T>*, FUN) [with T = plateauType, FUN =
ijCmpPlateauType]'
fill.cc:231:   instantiated from here
IOStream/include/ami_sort_impl.h:206: error: could not convert
`nb_runs' to `
    unsigned int&'
IOStream/include/ami_sort_impl.h:69: error: in passing argument 4 of
`void
    initializeRunFormation(AMI_STREAM<T>*, size_t&, size_t&, unsigned
int&)
    [with T = plateauType]'
    runFormation(AMI_STREAM<T>*, Compare*) [with T = labelElevType,
Compare =
    ijCmpLabelElevType]':
labelElevType, Compare = ijCmpLabelElevType]'
sortutils.h:66:   instantiated from `void sort(AMI_STREAM<T>**, FUN)
[with T = labelElevType, FUN = ijCmpLabelElevType]'
fill.cc:298:   instantiated from here
`nb_runs' to `
    unsigned int&'
`void
int&)
    [with T = labelElevType]'
    runFormation(AMI_STREAM<T>*, Compare*) [with T = boundaryType,
Compare =
    elevCmpBoundaryType]':
boundaryType, Compare = elevCmpBoundaryType]'
[with T = boundaryType, FUN = elevCmpBoundaryType]'
fill.cc:317:   instantiated from here
`nb_runs' to `
    unsigned int&'
`void
int&)
    [with T = boundaryType]'
Compare =
    labelCmpLabelElevType]':
labelElevType, Compare = labelCmpLabelElevType]'
sort(AMI_STREAM<T>*, FUN) [with T = labelElevType, FUN =
fill.cc:414:   instantiated from here
`nb_runs' to `
    unsigned int&'
`void
int&)
    runFormation(AMI_STREAM<T>*, Compare*) [with T = waterType, Compare =
    ijCmpWaterType]':
waterType, Compare = ijCmpWaterType]'
sort(AMI_STREAM<T>*, FUN) [with T = waterType, FUN = ijCmpWaterType]'
fill.cc:562:   instantiated from here
`nb_runs' to `
    unsigned int&'
`void
int&)
    [with T = waterType]'
Compare =
    ijCmpBoundaryType]':
boundaryType, Compare = ijCmpBoundaryType]'
[with T = boundaryType, FUN = ijCmpBoundaryType]'
fill.cc:674:   instantiated from here
`nb_runs' to `
    unsigned int&'
`void
int&)
Compare =
    waterCmpBoundaryType]':
boundaryType, Compare = waterCmpBoundaryType]'
[with T = boundaryType, FUN = waterCmpBoundaryType]'
fill.cc:680:   instantiated from here
`nb_runs' to `
    unsigned int&'
`void
int&)
make[2]: *** [OBJ.powerpc-apple-darwin7.0.0/FLOAT/fill.o] Error 1
make[1]: *** [subdirs] Error 1
make: *** [default] Error 1
Any particular reason this would happen? I'm using gcc3.3 on OSX 10.3
Cheers,
C.
Christopher J. Fonnesbeck ( c h r i s @ f o n n e s b e c k . o r g )
Georgia Cooperative Fish & Wildlife Research Unit, University of Georgia
