[GRASSLIST:2067] Re: error in compiling 5.7 with cxx support on OSX
Hamish
hamish_nospam at yahoo.com
Tue Dec 16 19:13:41 EST 2003
> Specifying c++ support in the configuration file results in the
> following build errors:
[... r.terraflow]
> fill.cc:231: instantiated from here
> IOStream/include/ami_sort_impl.h:206: error: could not convert
> `nb_runs' to `
> unsigned int&'
> IOStream/include/ami_sort_impl.h:69: error: in passing argument 4 of
> `void
> initializeRunFormation(AMI_STREAM<T>*, size_t&, size_t&, unsigned
> int&)
> [with T = plateauType]'
> make[2]: *** [OBJ.powerpc-apple-darwin7.0.0/FLOAT/fill.o] Error 1
> make[1]: *** [subdirs] Error 1
> make: *** [default] Error 1
> Any particular reason this would happen? I'm using gcc3.3 on OSX 10.3
Known problem, see
http://article.gmane.org/gmane.comp.gis.grass.devel/2668
