[GRASSLIST:2083] Re: How to enter coordinates on the DEFINE REGION screen
Glynn Clements
glynn.clements at virgin.net
Wed Dec 17 14:44:22 EST 2003
Maliheh wrote:
> > For everything except lat-lon, coordinates are just decimals (integers
> > or decimal fractions). For lat-lon, you can use either DD:MM:SS[NSEW]
> > or decimals.
> I want to create a new Location, as there is in GRASS manual, I had
> started by xy location, and define my region by decimals. but when I
> use g.region -pm it says: PROJ_INFO file not found for location
> mtest3.
That appears to be a bug in 5.3. It doesn't happen (for me) with
5.0.3, or with locations which have a defined projection. However, in
spite of that message, g.region appears to work OK.
Glynn Clements <glynn.clements at virgin.net>
