[GRASSLIST:2107] Re: How to enter coordinates on the DEFINE REGION screen
Maliheh
malihehs at yahoo.com
Mon Dec 22 15:20:54 EST 2003
yes, you are right, but I read in some previous messages that someone said that for each projection, we can use decimal. Really I have a jpeg image which I'v scanned it and by use of gpsdrive I found it's coordinates, I wrote those numbers as they seem in gpsdrive. sorry if my work is so silly!
Thank you so much for your responses.
Regards
Guillaume Criloux <guillaume.criloux at laposte.net> wrote:
It doesn't look like UTM coordinates to me. UTM coordinate in a give zone are in the are 500000 for X and 8 to 12 millions for Y (both in meters). Better check your coordinate system first.
Guillaume
*********** REPLY SEPARATOR ***********
On 21/12/2003 at 22:18 Maliheh wrote:
Hello list,
Sorry but I have a primary problem yet!
As I wrote it before, I know that at first we should create a xy location, and import a raster map, then transform it to a UTM location, so before use of i.target we should create another location, with UTM coordinate system. Am I right?
If yes, in this step I should create a new location:
DEFINE THE DEFAULT REGION
====== DEFAULT REGION ====
| NORTH EDGE: 35.73581 |
WEST EDGE| | EAST EDGE
51.40387 | | 51.43422
| SOUTH EDGE: 35.71539 |
PROJECTION: 1 (UTM) ZONE: 0
GRID RESOLUTION
East-West: 0.0002042
North-South: 0.0003035
Then it asks me:
à Do you wish to specify a geodetic datum for this location?(y/n) [y]
but my map is a jpg file that I dont know more detail about it, so I dont know what should I write for this and next question:
à Please specify ellipsoid name
Enter 'list' for the list of available ellipsoids
Hit RETURN to cancel request
As a result at the end of creating new location, GRASS says:
à LOCATION <mtest3_1> created
But the PROJECTION information files were not created!
You must run g.setproj successfully before projection software will work
Would you please help me, I want to create my own location, and work on my maps?
Your response will be so appreciated.
Best Regards
Maliheh
Do you Yahoo!?
New Yahoo! Photos - easier uploading and sharing
Do you Yahoo!?
Yahoo! Photos - Get your photo on the big screen in Times Square
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20031222/dab53952/attachment.html
