[GRASSLIST:2114] New Location
Maliheh
malihehs at yahoo.com
Wed Dec 31 05:34:33 EST 2003
Hello dear GRASS list,
I want to describe my problem from the beginning for you, I wish you can and you want to help me and also it can be helpful for others.
I want to create a new location for my region; I dont have any digital map that match my need, I have just a paper map and a GPS receiver, with use of gpsdrive I noted coordinates of four points on my map. Gpsdrive shows the coordinates like this:
Latitude: 35.73581 Longitude: 51.40387
And also I know that my region is between 34:52N , 34:21N and 50:10E , 53:10E; and my map scale is 1/12000 and the resolution of scanned map is 100dpi.
Now start the grass5.7 for creation new location:
a. LOCATION: test________ (enter list for a list of locations)
MAPSET: root__________ (or mapsets within a location)
DATABASE: /usr/local/src/GIS/grassdata
b. LOCATION <test> - doesn't exist
Would you like to create location <test>? (y/n) y
c. To create a new LOCATION, you will need the following information:
1. The coordinate system for the database
x, y (for imagery and other unreferenced data)
Latitude-Longitude
UTM
Other Projection
2. The zone for the UTM database
and all the necessary parameters for projections other than
Latitude-Longitude, x, y, and UTM
3. The coordinates of the area to become the default region
And the grid resolution of this region
4. A short, one-line description or title for the location
Do you have all this information for location <test>? (y/n) y
d. Please specify the coordinate system for location <test>
A x, y
B Latitude - Longitude
C UTM
D Other Projection
RETURN to cancel
> A
x, y coordinate system? (y/n) [y] y
e. Please enter a one line description for location <test>
> Create a new Location
Ok? (y/n) [y] y
f. DEFINE THE DEFAULT REGION
====== DEFAULT REGION ====
| NORTH EDGE: 36 |
WEST EDGE | | EAST EDGE
50 | | 53
| SOUTH EDGE: 34 |
PROJECTION: 0 (x, y) ZONE: 0
GRID RESOLUTION
East-West: 0.03
North-South: 0.02
g. projection: 0 (x,y)
zone: 0
north: 36
south: 34
east: 53
west: 50
e-w res: 0.02 (Changed to conform to grid)
n-s res: 0.03 (Changed to conform to grid)
total rows: 100
total cols: 100
total cells: 10000
Do you accept this region? (y/n) [n] > y
LOCATION <test> has been created!
I know that in some steps specially those with red highlight, Ive done something wrong, but I dont know how I should correct it. Because when I use g.region pm, it says: PROJ_INFO file not found for location test.
Therefore in other steps like use of r.in.gdal I have problems too.
Would you please help me, its so important for me. Your response will be sooooooooo appreciated, and I wish for you the best.
Regards
Maliheh
Do you Yahoo!?
Find out what made the Top Yahoo! Searches of 2003
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20031231/c6a958cf/attachment.html
