[GRASSLIST:5434] Re: grass5.0.1 and tcltk on macOSX
Glynn Clements
glynn.clements at virgin.net
Sat Feb 1 13:28:36 EST 2003
John Cartwright wrote:
> I'm trying to compile grass5.0.1 on macOS 10.2 and am having trouble with
> the tk library. Here's the relevant output form the compile statement:
> checking whether to use Tcl/Tk... yes
> checking for location of Tcl/Tk includes... /sw/include
> checking for tcl.h... yes
> checking for tk.h... yes
> checking Tcl version... 8.3
> checking Tk version... 8.3
> checking for location of Tcl/Tk library...
> checking for Tcl_Init in -ltcl... yes
> checking for Tk_MainWindow in -ltk... no
> checking for Tk_MainWindow in -ltk8.3... no
> checking for Tk_MainWindow in -ltk83... no
> configure: error: *** Unable to locate Tk library.
> I used fink to install the three tcltk packages:
> i tcltk 8.3.4-1 Tool Command Language and the Tk toolkit.
> i tcltk-dev 8.3.4-1 Tool Command Language and the Tk toolkit.
> i tcltk-shlibs 8.3.4-1 Tool Command Language and the Tk toolkit.
> And indeed do see wish and the tk shared library (libtk8.3.dylib).
> Can anyone suggest a way around this problem?
If configure fails to detect a library which you know is installed,
check the config.log for error messages; the ones at the end of the
file are what's relevant.
The most common reason for such problems is that the library requires
some other library which isn't installed.
Glynn Clements <glynn.clements at virgin.net>
