[GRASSLIST:5515] Re: problem in g.select.pg
Markus Neteler
neteler at itc.it
Mon Feb 10 03:25:06 EST 2003
On Sat, Feb 08, 2003 at 10:59:37AM +0100, Ingo Wichmann wrote:
> Miha STAUT schrieb:
> > I managed to get Postrges/GRASS interface to work by copying the
> > libpq.so.2 and changing its name to libpq.so. Is this fine or should I
> > correct the mistake I made as you said. I run RedHat 7.3 with GRASS
> > 5.0.0 and PostgreSQL 7.2.
> > Is this the reason I can not install the R/PostgreSQL interface?
The latter question is probably related to another mailing list,
but here some hints:
http://grass.itc.it/statsgrass/learning_r1.html#Connecting_R_to_RDBMS
... which I have added recently. The installation of R/PostgreSQL interface
has changed recently and is not well documented on the R web sites.
Above solution works well (for me).
Markus Neteler
