[GRASSLIST:5508] Re: problem in g.select.pg
    Ingo Wichmann
    wichmann at uni-wuppertal.de
    Sat Feb  8 04:59:37 EST 2003
Miha STAUT schrieb:
> I managed to get Postrges/GRASS interface to work by copying the
> libpq.so.2 and changing its name to libpq.so. Is this fine or should I
> correct the mistake I made as you said. I run RedHat 7.3 with GRASS
> 5.0.0 and PostgreSQL 7.2.
> Is this the reason I can not install the R/PostgreSQL interface?
I've never used R.
Ingo
