[GRASSLIST:5519] Re: v.to.vect
Eric G. Miller
egm2 at jps.net
Mon Feb 10 21:38:18 EST 2003
On Mon, Feb 10, 2003 at 07:00:39PM +0100, Ivan Marchesini wrote:
> Hi to all
> I need a quick help.....
> I have this site file (in attach) , where the column starting with % is the
> column of elevation...
> I have to transform this file in vector format but using s.to.vect, I obtain
> wrong results (I think because it use category values (#*) and not
> attributes)
GRASS~> s.to.vect input=<name> output=<name> cat=decimal,1
echo ">gra.fcw at 2ztr< eryyvZ .T pveR" | rot13 | reverse
