[GRASSLIST:5522] Re: v.to.vect
Ivan Marchesini marchesini at unipg.it
Tue Feb 11 13:01:55 EST 2003
Thank you very much!!!!!
bye
Ivan
Alle 03:38, martedì 11 febbraio 2003, Eric G. Miller ha scritto:
> On Mon, Feb 10, 2003 at 07:00:39PM +0100, Ivan Marchesini wrote:
> > Hi to all
> > I need a quick help.....
> > I have this site file (in attach) , where the column starting with % is
> > the column of elevation...
> > I have to transform this file in vector format but using s.to.vect, I
> > obtain wrong results (I think because it use category values (#*) and not
> > attributes)
> GRASS~> s.to.vect input=<name> output=<name> cat=decimal,1
Ivan Marchesini
University of Perugia
Italy
