[GRASSLIST:5526] Problems compiling under Linux
Ben Logan
ben at wblogan.net
Wed Feb 12 10:40:17 EST 2003
Hello,
I just downloaded the source for grass5.0beta11, and can't get it to
compile. I'm running Redhat 8.0 on an i586, and AFAIK I have all the
requirements (I don't have R installed, but I don't need the scripting
capability at this point). I also have the latest GDAL installed.
I captured the output from the configure script and make, so maybe
someone can help. The error seems to be due to a missing file, but
I'm not sure that's the original error. The un-compressed output is
over 1Mb, and is available here:
http://cyclist.wblogan.net/other/typescript
A gzipped version (about 80Kb) is here:
http://cyclist.wblogan.net/other/typescript.gz
If you use less to look at the file, you can use 'less -R' to get rid
of the ANSI codes around my prompt. If anyone needs more info, just
say so and I'll send it.
Thanks for any help,
Ben
Ben Logan
Google Answers Researcher
answers.google.com
When you're searching for information, Google Answers.
