[GRASSLIST:5536] v.build problem?
    Brent Wood
    b.wood at niwa.co.nz
    Thu Feb 13 01:15:54 EST 2003
I have a site map containg a few hundred thousand points (& only
points). I'm converting it to vector.
Why does v.build require 40 odd minutes to run on a P4 2.4Ghz?
It only uses 6% of system memory for the whole dataset, & I can't see what
topology is required for a map with only point features.
I know it will get there eventually, just wondering what my cpu is so
busy doing?
Is this worth a wish list/bug report?
Thanks,
  Brent Wood
