[GRASSLIST:5571] Re: Geocentric System
Brent Wood
b.wood at niwa.co.nz
Sun Feb 16 15:13:46 EST 2003
On Thu, 13 Feb 2003, Christoph Deuchler wrote:
> Hi all,
> is it possible to create a location using a geocentric lat/lon
> coordinate system with a longitude range of 0° to 360°? It would safe
> me a lot of work not having to reproject all data for a Mars
> information system.
I'm using 0-360 degree coords to work across the 180 meridian. It works
for vector data, and I believe the CVS source has been patched to enable
this for raster and site data. The list archives from a couple of weeks
ago will have a record of this.
Note that although with a display region of 170-190 X axis no site
data east of 180 (ie: 180-190) data displays in the X monitor using V5.0,
it is successfully queried, so the problem was a display rather than data
management one as far as I can tell.
Cheers
