[GRASSLIST:5542] GRASS 5.0.1 compilation issues
Wayne Gibson gibson at coas.oregonstate.edu
Thu Feb 13 14:48:21 EST 2003
I'm attempting to compile GRASS 5.0.1 on a SunBlade 1000.  There are quite a few
"failed" messages in the config.log file.  I assume that is normal.  When I
"make" the package, the only errors written to "error.log" are
Compilation error in module: src/raster/r.tiff (ignored)
Compilation error in module: src/display/devices/PNGdriver (ignored)
I assume these can be ignored.
Now I attempt to start GRASS and I get the error message:
   Sorry, I need to know a more specific terminal type than "".^M
I've tracked it down to the program call "set_data" found in "etc/Init.sh".
When I replace the "set_data" program with the one from the pre-compiled SUN
package, all works just fine.
I thought it might be a library issue so I ran "ldd" to see which dynamic
libraries are required:
ldd /usr/local/grass5/etc/set_data
        libncurses.so.5 =>       /usr/local/lib/libncurses.so.5
        libcurses.so.1 =>        /usr/lib/libcurses.so.1
        libm.so.1 =>     /usr/lib/libm.so.1
        libnsl.so.1 =>   /usr/lib/libnsl.so.1
        libz.so.1 =>     /usr/lib/libz.so.1
        libsocket.so.1 =>        /usr/lib/libsocket.so.1
        libc.so.1 =>     /usr/lib/libc.so.1
        libdl.so.1 =>    /usr/lib/libdl.so.1
        libmp.so.2 =>    /usr/lib/libmp.so.2
        /usr/platform/SUNW,Sun-Blade-1000/lib/libc_psr.so.1
If I swap "set_data" with the pre-compiled version, the executable points to the
same libraries so it is not an issue with which library is used.
I also checked source code to see if the error message was coming from the GRASS
source code or some system call.  I could not find the offending message in any
.c or .h file so I assume(?) it is a system call.  I'm using the Sun Workshop 6
C compiler.
Has anyone seen this type of message before?
Thanks,
Wayne
Wayne Gibson
Oregon State University
(541) 737-5696
