[GRASSLIST:5584] Grass to ArcInfo Grid
    Xueming Wu
    xwu at cse.unl.edu
    Mon Feb 17 12:03:50 EST 2003
Greetings,
I used r.out.arc to convert a Grass raster into ArcInfo
Grid ascii file. But when I imported this Grid ascii
file into ArcInfo, only two categories showed up. There
are 10 categories in the original Grass raster. I used
the following command:
r.out.arc input= output=
And I am using GRASS 5.0.0pre4. Any suggestion or comment?
Thank you.
Xueming
