[GRASSLIST:5618] Re: Linking Monitors
    Eric G. Miller
    egm2 at jps.net
    Thu Feb 20 22:19:13 EST 2003
On Fri, Feb 21, 2003 at 01:07:13AM -0300, Sandro Klippel wrote:
> I'm also interested. How I do this with d.frame ?
If you want to pan in one monitor/frame and have it pan in another
monitor/frame ... can't do it without specifically redrawing each
frame after a pan.  Not the most convenient...
> On Thu, 20 Feb 2003 18:50:17 -0800
> "Eric G. Miller" <egm2 at jps.net> wrote:
> > On Thu, Feb 20, 2003 at 09:52:35AM -0800, Daniel Victoria wrote:
> > > Is it possible to geographycally link to display
> > > monitors (x0 and x1 for example) so I could visually
> > > compare two images, using d.pan on just one monitor?
> > d.frame?
echo ">gra.fcw at 2ztr< eryyvZ .T pveR" | rot13 | reverse
