[GRASSLIST:5619] Re: d.zoom with vector map
    cheg01 at attbi.com
    cheg01 at attbi.com
    Thu Feb 20 23:14:11 EST 2003
I am using Grass 5.0.0 from the command line on Solaris 8 Sparc. The
problem is that when you type in "d.zoom" the first prompt  is:
Enter the name of an existing raster file
Enter 'list' for a list of existing raster files
Hit RETURN to cancel request
You cannot continue without entering a raster file name because it
interprets "RETURN" as cancel. Also, "d.zoom help" shows that "rast=name"
is manditory if you are not using the parser. Am I missing something?
----- Original Message -----
To: <GRASSLIST at baylor.edu>
Sent: Thursday, February 20, 2003 6:48 PM
Subject: [GRASSLIST:5615] Re: d.zoom with vector map
> On Thu, Feb 20, 2003 at 09:06:57AM -0800, cheg01 at attbi.com wrote:
> > d.zoom will not work unless a raster file name is provided. Why won't
it
> > work with vector files only? This a is an inconvenience when importing
> > vector formats into a new location before converting them to raster.
> Which version of GRASS?  AFAIK, there was such a problem and it was
> fixed.  The problem was actually with d.vect (or whatever).
> echo ">gra.fcw at 2ztr< eryyvZ .T pveR" | rot13 | reverse
