[GRASSLIST:5620] Re: d.zoom with vector map
Glynn Clements
glynn.clements at virgin.net
Thu Feb 20 23:39:33 EST 2003
Eric G. Miller wrote:
> > d.zoom will not work unless a raster file name is provided. Why won't it
> > work with vector files only? This a is an inconvenience when importing
> > vector formats into a new location before converting them to raster.
> Which version of GRASS? AFAIK, there was such a problem and it was
> fixed. The problem was actually with d.vect (or whatever).
No, it's a problem with d.zoom, still present in CVS HEAD:
if(!rast && !vect && !site)
rmap->required = YES;
just->answer = 1;
The rast, vect and site variables correspond to whether any raster,
vector or site maps are currently displayed in the monitor (IOW, the
results of D_get_{cell,dig,site}_list()).
If no maps are displayed in the monitor, you have to specify the rast=
option, and -j is assumed.
IMO, most of d.zoom is bogus; it should just change the region then
re-run the command list. IOW, the interactive equivalent of
"g.region ... ; d.redraw".
Actually, it should probably just be subsumed into d.dm.
Glynn Clements <glynn.clements at virgin.net>
