[GRASSLIST:5656] Re: arrow keys not working
Glynn Clements glynn.clements at virgin.net
Mon Feb 24 14:23:01 EST 2003
Wayne Gibson wrote:
> After compiling on a SUN, the cursor keys are not working in the
> window where the user interactively can set LOCATION, MAPSET, and
> DATABASE. I believe this is generated from "etc/set_data". By the
> way, this is the same program that experienced compiling problems
> before due to the curses library and since fixed (at least I thought
> so).
Look at the HAVE_KEYPAD line in src/include/config.h. If the macro is
undefined, then your curses library doesn't support the use of cursor
keys (at least, configure failed to detect the keypad() function). If
the macro is defined, then either it's a bug in the curses library, or
xterm's termcap/terminfo entry is broken.
BTW, Ctrl-K should have the same effect as the up-arrow key, Ctrl-L
the same effect as the right-arrow key, and Return/LineFeed the same
as the down-arrow key; there isn't an exact equivalent to the
left-arrow key.
> After I enter <ESC><ENTER> and proceed to working in the GRASS
> terminal window, then the cursor keys start working again.
Bash doesn't use curses; it has it's own ad-hoc mechanism for handling
extended keys.
GRASS uses the standard curses interface, i.e. it calls keypad() to
enable the cursor keys, then processes the extended codes (KEY_LEFT
etc) which the curses library should generate for extended keys.
If curses fails to process the keys correctly, then they won't work.
Glynn Clements <glynn.clements at virgin.net>
