[GRASSLIST:5658] Re: arrow keys not working
    Wayne Gibson
    gibson at coas.oregonstate.edu
    Mon Feb 24 16:00:35 EST 2003
Glynn,
>From: Glynn Clements <glynn.clements at virgin.net>
>MIME-Version: 1.0
>Content-Transfer-Encoding: 7bit
>To: Wayne Gibson <gibson at coas.oregonstate.edu>
>Cc: grasslist at baylor.edu
>Subject: Re: [GRASSLIST:5655] arrow keys not working
>Wayne Gibson wrote:
>> After compiling on a SUN, the cursor keys are not working in the
>> window where the user interactively can set LOCATION, MAPSET, and
>> DATABASE. I believe this is generated from "etc/set_data". By the
>> way, this is the same program that experienced compiling problems
>> before due to the curses library and since fixed (at least I thought
>> so).
>Look at the HAVE_KEYPAD line in src/include/config.h. If the macro is
>undefined, then your curses library doesn't support the use of cursor
>keys (at least, configure failed to detect the keypad() function). If
>the macro is defined, then either it's a bug in the curses library, or
>xterm's termcap/terminfo entry is broken.
The macro is define.
In addition, I tested out the ncurses library with the supplied test program
"ncurses", option "a"( keyboard and mouse input test).  The arrow keys are
correctly mapped as:
0405 KEY_RIGHT
0403 KEY_UP
0404 KEY_LEFT
0402 KEY_DOWN
Also, the same test program with option "g"(display windows and scrolling)
correctly allows me to move around the screen with the arrow keys.
I compared the libraries required by "set_data" in the 5.0.0 pre-compiled
version and 5.0.1 that I compiled.  The pre-compiled uses both libncurses and
libcurses while the version I compiled uses libncurses only.  It that what one
should expect? (5.0.0 "set_data" works)
>BTW, Ctrl-K should have the same effect as the up-arrow key, Ctrl-L
>the same effect as the right-arrow key, and Return/LineFeed the same
>as the down-arrow key; there isn't an exact equivalent to the
>left-arrow key.
It would be great to have both left and right arrow keys working.  Those are the
2 I use the most.
>> After I enter <ESC><ENTER> and proceed to working in the GRASS
>> terminal window, then the cursor keys start working again.
>Bash doesn't use curses; it has it's own ad-hoc mechanism for handling
>extended keys.
>GRASS uses the standard curses interface, i.e. it calls keypad() to
>enable the cursor keys, then processes the extended codes (KEY_LEFT
>etc) which the curses library should generate for extended keys.
>If curses fails to process the keys correctly, then they won't work.
Wayne
Wayne Gibson
Oregon State University
(541) 737-5696
