[GRASSLIST:5672] DXF problems
    Dr. Mohamad Firuz Ramli
    firuz at fsas.upm.edu.my
    Wed Feb 26 04:05:16 EST 2003
Dear list,
I have problem with dxf data. I managed to import dxf data using this procedure.
The first data layer is "contour" and the second is "river" data
i)  v.in.dxf.
ii) v.in.dxf3d (for contour data only)
iii)v.support
I managed to display both in the  monitor using d.vect correctly.
i)However when I try to convert vector data of "river" to raster
using v.to.rast, the processing seems running well, but there
is no data in the newly converted raster data. However when i try
v.to.rast to the "contour", it worked.
For "river"
In the dialog appeared during the processing: Processing line 0
        Processing site 0
whereasa in v.to.rast for "contour"            Processing line 2567
It seems that the processsing cannot identified the line
ii)When I try to use v.surf.rst to the "contour" layer, nothing happened
and in the dialog
percent complete: Killed
Thanks in advance.
Firuz
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20030226/de1b2c3f/attachment.html
