[GRASSLIST:5675] Re: DXF problems
    Sandro Klippel
    sandro.klippel at talha-mar.com.br
    Wed Feb 26 07:25:20 EST 2003
On Wed, 26 Feb 2003 17:05:16 +0800
"Dr. Mohamad Firuz Ramli" <firuz at fsas.upm.edu.my> wrote:
> Dear list,
> I have problem with dxf data. I managed to import dxf data using this procedure.
> The first data layer is "contour" and the second is "river" data
> i)  v.in.dxf.
> ii) v.in.dxf3d (for contour data only)
> iii)v.support
> I managed to display both in the  monitor using d.vect correctly.
> i)However when I try to convert vector data of "river" to raster
> using v.to.rast, the processing seems running well, but there
> is no data in the newly converted raster data. However when i try
> v.to.rast to the "contour", it worked.
> For "river"
> In the dialog appeared during the processing: Processing line 0
>        Processing site 0
the lines needs to have a category number. try
v.llabel map=river
and them v.to.rast input=river output=river
> whereasa in v.to.rast for "contour"            Processing line 2567
> It seems that the processsing cannot identified the line
> ii)When I try to use v.surf.rst to the "contour" layer, nothing happened
> and in the dialog
try use -c flag (use category data for elevations)
> percent complete: Killed
> Thanks in advance.
> Firuz
Sandro Klippel <sandro.klippel at talha-mar.com.br>
talha-mar projetos ambientais
Conselheiro d'Avila 190
Porto Alegre,RS 91040-450
+55 (51) 3344-7451
w w w . t a l h a - m a r . c o m . b r
