[GRASSLIST:5690] Unrectified DXF importation
    Dr. Mohamad Firuz Ramli
    firuz at fsas.upm.edu.my
    Fri Feb 28 02:42:09 EST 2003
Dear list
Thanks  to Sandro for helping me in my first problems
with dxf data.
I have another problems.
I try to import unrectified dxf layer. I manage to do it.
However when I did the transformation using v. transform,
it shows the transformation process with the residual value.
But when I tried to display the rectified dxf. It did not show anything.
I followed the procedure in Neteler and Mitasova's book but I encounter
a problem such as above.
This is the procedure that I did.
v.in.dxf -a dxf=vmap.dxf prefix=vmap      --to import dxf data into ascii
I want to import road layer inside vmap
 v.in.ascii in=vmap.road out=vmap_roadxy
v.support vmap_roadxy
g.region -p vect=vmap_roadxy
d.erase
d.vect vmap_roadxy
I managed to display the vmap_roadxy layer on the screen and identify four gcpoints
in x and y coordinates and its location on the map for the real coordinates and
save in in ASCII table point as roadgcp
After that
v.transform in=vmap_road out=vmap_roadtrans point=roadgcp    (as in Neteler and Mitasova book)
ERROR:Could not find input vector vmap_road
After that I change the input to the one that I convert to binary file
v.transform in=vmap_roadxy out=vmap_roadtrans point=roadgcp
The map is transformed with the residual value
Transformation is complete
v.support vmap_roadtrans
g.region -p vect=vmap_roadtrans
However, it shows that the region of vmap_roadtrans is similar
to the one that of original or unrectified.
However,  I tried
d.vect vmap_roadtrans
but nothing coming out.
Could anyone please help me in this matter.
Thanks in advance
Firuz
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20030228/7ef94e4b/attachment.html
