[GRASSLIST:5296] Re: DFX import
Nick Cahill
ndcahill at facstaff.wisc.edu
Tue Jan 7 11:28:38 EST 2003
Baylor University is currently experiencing E-mail problems. We cannot assure that your message will be delivered in a timely manner. You do not neeed to re-send your message, it has been safely recieved by our system for eventual delivery to the recipient. We intend to have our system fully restored by Monday, Jaunary 13.
I've found that GRASS doesn't do well with some types of CAD lines. I
use Microstation rather than AutoCAD, and have also had problems
importing contour lines. I finally found that some of them were typed
as complex elements -- a series of polylines which were grouped
together. Microstation has a tool which breaks down these complex
elements into their component parts. I think the equivalent type of
element in AutoCAD is a block - you might see if some of your contour
lines are blocks, and if so, try to break them down into polylines.
Hope this helps--
Nick Cahill
