[GRASSLIST:5414] Re: please help me generate an adjaceny list
Radim Blazek blazek at itc.it
Fri Jan 31 03:07:13 EST 2003
On Friday 31 January 2003 08:04 am, Jeff D. Hamann wrote:
> Help! I'm in dire need of an adjacency list for a polygon layer. I haven't
> been successful in getting GRASS to compile (under cygwin) and have never
> tried to add a command to GRASS. I *need* to generate an adjaceny file for
> a project that builds a list of which polygons are next to which polygons
> for all the polygons in a layer (liek the arcinfo palinfo command). Is
> there a way to do this using one of the output files (v.out.arc?) and a
> script? I've never asked anything in a frantic way like this, but I need
> to generate the file in short order or suffer a weekend or converting all
> my GRASS work to arcinfo. Please, think of the children.
> OR
> can someone point me in the right direction to adding a GRASS module?
> Thanks for listening,
> Jeff.
You must use topology, so export + script does not help.
If topology is built (v.support), each boundary has information
about area on left/right side. Code may be like this:
for (i=1; i <= Map.n_lines; i++) {
    Line = &(Map.Line[i]);
    if (Lines->type != AREA)   continue;
    lcat = rcat = 0;
    if (Lines->left != 0)
        lcat = Map.Att[Map.Area[Lines->left].att].cat;
    if (Lines->right != 0)
        rcat = Map.Att[Map.Area[Lines->right].att].cat;
    fprintf (stdout, "%d %d", lcat, rcat);
Radim
