[GRASSLIST:601] Re: Understanding why r.flow gives me bad results.
Antonio
nightnavigator at libero.it
Thu Jul 3 17:36:09 EDT 2003
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
* giovedì 03 luglio 2003, alle 11:42, David Finlayson scrive:
> Your DEM may have little pits (closed basins) that stop drainage.
> Usually, these pits are artifacts of the DEM so you can use a program
> like r.fill.dir to "fill" the pits and created a "filled" dem.
Yes, i realized that r.flow was rather nasty about pits. I read it in
the man page.
> Use the "filled" dem in r.flow and see if the results are better. r.flow
> is pretty picky about flat areas (see the notes in the manual). You may
> have better luck with r.watershed and r.terraflow for extracting the
> river networks.
Yes, Markus has already told me about r.terraflow. I'll give it a try
but first I have to learn how to use CVS on my Debian box as I seem to
understand that r.terraflow is available only in the source tree.
(howcome it's not available in the weekly snapshots?)
Thanks for the "filled" option which I didn't consider. I'll give it a
try.
Bye
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.2 (GNU/Linux)
iD8DBQE/BKHJIRaQQEznKxURAhTkAKDgtseoXbNnHgItoYVw6U6kCLj2gACgpWwd
GPbY2FrS3avqzjYtgaWtN7w=
=mbN4
-----END PGP SIGNATURE-----
