[GRASSLIST:669] Re: configure with postgres on OS X
David Orme
d.orme at imperial.ac.uk
Wed Jul 9 12:01:19 EDT 2003
Thanks for the help - I now, of course, have a follow up...
The postgres library is: /usr/local/psql/lib/pqsql.a
The config.log shows a problem with compiling a test file with gcc
> configure:8974: checking for location of PostgreSQL library
> configure:9003: checking for PQsetdbLogin in -lpq
> configure:9020: gcc -o conftest -g -O2 -L/usr/local/lib conftest.c
> -lpq 1>&5
There are four variants of the last line, all of which fail, using
combinations of -lcrypto and -lssl.
My gcc version is:
> Reading specs from /usr/libexec/gcc/darwin/ppc/3.1/specs
> Thread model: posix
> Apple Computer, Inc. GCC version 1175, based on gcc version 3.1
> 20020420 (prerelease)
Any suggestions?
Thanks in advance,
David
On Wednesday, July 9, 2003, at 02:39 pm, Glynn Clements wrote:
> David Orme wrote:
>> I'm trying to install GRASS 5.0.2 on OS X (10.2.6) with postgresql
>> support and I can't figure out what the --with-postgres-libs argument
>> is looking for.
> It is typically the directory containing libpq (the PostgreSQL client
> library), e.g. libpq.a or libpq.dylib.
>> I've tried looking through the configure script but my
>> shell programming isn't good enough to work it out.
>> I've tried:
>> ./configure --with-postgres-includes=/usr/local/pgsql/include
>> --with-postgres-libs=/usr/local/pgsql/lib
>> and
>> --with-postgres-libs=/usr/local/lib
> These look normal, although I don't know where libpq is.
> However, note that the configure check isn't "does this file exist?",
> but "does linking against this library succeed?".
> Even if the library is present and you provide the correct path, many
> other factors could cause linking to fail. Look in the config.log
> file, after the line:
> Any error messages which result from linking should follow.
> Glynn Clements <glynn.clements at virgin.net>
