[GRASSLIST:673] Re: raster categories and floating point attribute
values
Michel Wurtz
mjwurtz at wanadoo.fr
Wed Jul 9 16:01:07 EDT 2003
Steven Stoddard wrote:
> I am currently in the process of learning grass and trying to assemble a
> database to work off of for my research. I am importing many files and
> trying to get them into a raster format that is amenable to
> analysis--floating point or integer maps. I have maps though that were
> imported from .e00 that are in raster format, but are categorized
> sequentially (e.g. 1-120) and their labels are a floating point value.
> How do I get rid of the category number and instead have only the fp
> value so I can do manipulations with mapcalc etc?
> Just for background, the imported map was first in vector format and all
> polygons were assigned a unique id with a floating point value as the
> attribute. I reclassified this map so that the categories at least
> corresponded to same floating point values and were sorted in increasing
> fashion.
You can use r.reclass the same way as v.reclass on the file imported with
m.in.e00 : just transform the cat file in soething usable as input for
r.reclass. What I don't know is how to force the resulting file to be
a floating value raster... Maybe it is easier to start from the vector
file and use v.to.rast (with the appropriate dig_cats file) to produce
the raster file...
Here follows a copy a message I posted some days ago :
As a reminder : If there is only one attribute (other than the standard ESRI
attributes for lines or areas), ther is only one dig_cats file created, and
its name is like the dig file name. If there is many attributes, there is
as many dig_cats files, named <vector_file_name>.<attribute_name>. In this case
the first thing to do is to go in the dig_cats directory and set a symbolic
link to the dig_cats file you want as the new dig_att values.
After that, you need only a two line command to change the att values. The
best is to take an example :
dig file name is brucom,
dig_att/brucom looks like :
# 48 categories
brucom
0.00 0.00 0.00 0.00
1:67482
2:67492
3:67354
4:67240
etc.
What you have to type :
export LOCATION=<your mpaset location>
sed -e '1,4d' -e 's/:/ = /' $LOCATION/dig_cats/brucom | v.reclass input=brucom
output=brucom1 type=area
v.support brucom1
The first line was added since $LOCATION is no longer set at grass startup...
The second one do the job : sed convert the dig_att file in a form usable by
v.reclass. You have to change
- the file names and the location (obviously)
- the type=area in type=line if you have lines instead of areas
The third line is mandatory for some other programs to work (v.digit, d.what.vect,
etc.)
Michel Wurtz - Auzeville-Tolosane
