[GRASSLIST:700] Re: rectifying vector map
David Orme
d.orme at imperial.ac.uk
Fri Jul 11 05:44:06 EDT 2003
I've just been trying to do exactly this (with added complications that
the vector data is in eps format and full of extra features that I need
to get rid of...).
There is a command v.transform that will rectify a vector but it will
only do 1st order transformations. If my understanding of
georeferencing is right, then you should be able to create a location
in the same projection as the vector map source and then a first order
transform is all that should be needed. (If I've got this wrong can
someone tell me!). Unfortunately, for my data we have no projection
information on the vector graphics files and so I think I'm going to
have to go down the rasterize, i.rectify, r.poly route..
David
On Friday, July 11, 2003, at 10:04 am, Moritz Lennert wrote:
> Hi all,
> Is it possible to rectify a vector map, i.e. import a map that was
> drawn
> in x,y coordinates and then rectify it to a real projection system, or
> does one have to transform the map into raster and then use i.rectify ?
> Moritz
