[GRASSLIST:821] Customizing startup
David Finlayson
dfinlays at u.washington.edu
Sat Jul 26 09:39:23 EDT 2003
I would like grass to source a bash script after startup. Can this be
automated? For example, adding a line to Init.sh somewhere?
I use Grass 5.0.2 on Cygwin/XP and would like to make a few aliases to
ease starting monitors (which is a bit tedious right now in Cygwin
because you need to both start it and then select it before first
use---I think this is a known bug).
Currently I source a file manually after startup that has a few aliases
defined:
alias x0="d.mon start=x0; d.mon select=x0"
alias x1="d.mon start=x1; d.mon select=x1"
and so on...
Thanks,
David Finlayson
School of Oceanography
Box 357940
University of Washington
Seattle, WA 98195-7940
USA
Office: Marine Sciences Building, Room 112
Phone: (206) 616-9407
Web: http://students.washington.edu/dfinlays
