[GRASSLIST:827] Re: Problems importing a GMT grd file
David Finlayson dfinlays at u.washington.edu
Sun Jul 27 20:09:36 EDT 2003
Thank you.
The binary grid you created looked good.  I will try the gmt-help list
to see if there are known bugs in the Cygwin version of grdreformat.
David
Sandro Klippel wrote:
> David,
> I get the same error on your binary file. But the converted file from
> gmt grid work fine. So, the problem is in your 'grdreformat'.
> I put the new binary file on:
> www.talha-mar.com.br/programas/triangle2.zip
> output of grdinfo:
> triangle.grd: Title:
> triangle.grd: Command: triangulate -JX25i/40i median.xyz -I10 -E
> -Gtriangle.grd -R534090/548020/5322430/5346610 -V -M
> triangle.grd: Remark:
> triangle.grd: Normal node registration used
> triangle.grd: grdfile format # 0
> triangle.grd: x_min: 534090 x_max: 548020 x_inc: 10 units: user_x_unit
> nx: 1394
> triangle.grd: y_min: 5.32243e+06 y_max: 5.34661e+06 y_inc: 10 units:
> user_y_unit ny: 2419
> triangle.grd: z_min: -11.8154 z_max: 47.3911 units: user_z_unit
> triangle.grd: scale_factor: 1 add_offset: 0
> output of r.info:
> Type of Map:  raster              Number of Categories: 255
> Data Type:    FCELL
> Rows:         2419
> Columns:      1394
> Total Cells:  3372086
> Projection: UTM (zone 0)
> N:    5346610    S:    5322430   Res: 9.99586606
> E:     548020    W:     534090   Res: 9.9928264
> Range of data:    min =  -11.815351 max = 47.391102
> Data Source:
> Data Description: generated by r.in.bin
> On Sat, 2003-07-26 at 19:09, David Finlayson wrote:
>>I placed the files on our web server:
>>http://www.ocean.washington.edu/data/pugetsound/grass/triangle.zip
>>Thanks for your help with this.
>>David
>>>Perhaps you right. I'm not know cygwin, but it worked pretty well on
>>>linux (grdreformat-r.in.bin).
>>>I can test it for you. Send me your arquives (both .grd and .bin).
>>>On Sat, 2003-07-26 at 16:40, David Finlayson wrote:
>>>>I removed the -R and got the same result.  I wonder if this is a cygwin
>>>>problem?
>>>>Triangle.grd works fine in GMT plots.  Something is falling appart
>>>>during either the reformat step or during import.
>>>>Unfortuantley, I don't have a linux box with grass installed to verify that.
>>>>David
>>>>>David,
>>>>>you should not put the '-R' option without specify boundaries. You only
>>>>>need this to select partial areas from original grid.
>>>>>try,
>>>>>grdreformat triangle.grd=0 triangle.bin=1 -V (without '-R')
>>>>>Sandro.
>>>>>On Sat, 2003-07-26 at 03:53, David Finlayson wrote:
>>>>>>I tried the grdreformat line as you suggested, now r.in.bin gives the
>>>>>>following error:
>>>>>>North must be larger than South
>>>>>>Has the header been corrupted in the conversion?  Does r.in.bin accept
>>>>>>scientific (exponential) notation in the header?  The Northing
>>>>>>coordinates are given in exponential notiation in triangle.grd as you
>>>>>>can see below in my first post.
>>>>>>This is a UTM Zone 10 grid created from XYZ data with the following
>>>>>>script (Note the UTM coordinates and non-geographic projection):
>>>>>>echo " *** Filter the data and convert to grid *** "
>>>>>>gmtconvert 02022_utm.xyz -bo > utm.b
>>>>>>blockmedian utm.b -bi -I10 -R534090/548020/5322430/5346610 -V > median.xyz
>>>>>>echo " *** Build Triangle Grid *** "
>>>>>>triangulate median.xyz -I10 -E -Gtriangle.grd -R -JX25i/40i -V -M >
>>>>>>lines.dat
>>>>>>echo " *** Convert Grid to proper type for GRASS *** "
>>>>>>grdreformat triangle.grd=0 triangle.bin=1 -V -R
>>>>>>Then in GRASS:
>>>>>>r.in.bin -fh in=triangle.bin out=shoals.gmt
>>>>>>Thanks for your help!
>>>>>>David
>>>>>>>Try use
>>>>>>>and then
>>>>>>>>r.in.bin -hf in=triangle.bin out=shoals.gmt
>>>>>>>On Fri, 2003-07-25 at 15:18, David Finlayson wrote:
>>>>>>>>I have created a GMT grid file from point data using GMT's triangulate
>>>>>>>>command.  When I tried to import the grd with r.in.bin, I received an
>>>>>>>>error saying there was an invalid row value. Is there something I am
>>>>>>>>doing wrong?
>>>>>>>>Here are some details:
>>>>>>>>GRASS:~/shoals > gridinfo triangle.grd
>>>>>>>>triangle.grd: Command: triangulate -JX25i/40i median.xyz -I2 -E
>>>>>>>>triangle.grd: x_min: 534090 x_max: 548020 x_inc: 2 units: user_x_unit
>>>>>>>>nx: 6966
>>>>>>>>triangle.grd: y_min: 5.32243e+06 y_max: 5.34661e+06 y_inc: 2 units:
>>>>>>>>user_y_unit ny: 12091
>>>>>>>>triangle.grd: z_min: -11.945 z_max: 48.91 units: user_z_unit
>>>>>>>>GRASS:~/shoals > r.in.bin -hf in=triangle.grd out=shoals.gmt
>>>>>>>>Illegal row value
>>>>>>>>I am using GRASS 5.0.2 (April 2003) and GMT 3.4.3 both on Cygwin/XP
>>>>>>>>Thanks
>>>>>>>>David Finlayson
>>>>>>>>School of Oceanography
>>>>>>>>Box 357940
>>>>>>>>University of Washington
>>>>>>>>Seattle, WA  98195-7940
>>>>>>>>USA
>>>>>>>>Office: Marine Sciences Building, Room 112
>>>>>>>>Phone: (206) 616-9407
>>>>>>>>Web: http://students.washington.edu/dfinlays
>>>>>>David Finlayson
>>>>>>Box 357940
>>>>>>USA
>>>>David Finlayson
>>>>Box 357940
>>>>USA
>>David Finlayson
>>Box 357940
>>USA
David Finlayson
Box 357940
USA
