[GRASSLIST:843] Re: QTDRIVER: an alternative graphics driver for GRASS
    Bernhard Reiter
    bernhard at intevation.de
    Mon Jul 28 10:01:40 EDT 2003
On Mon, Jul 28, 2003 at 09:53:16AM +0100, Ron Yorston wrote:
> I am pleased to announce the first public release of QTDRIVER, an alternative
> graphics driver for GRASS.  QTDRIVER is implemented using the cross-platform
> Qt toolkit.  This means that it should be possible to compile it for any
> platform that Qt supports.  I've built versions for i386/Linux and the Sharp
> Zaurus handheld computer.
Great!
It is also Free Software under GNU GPL I read from the sources.
Note that this means that you can only link it to the GNU GPL compatible
versions of QT (that is QT Free for X11,/Embedded and Mac),
but not Qt Windows.
> The Zaurus version is of particular interest as it allows GRASS to be used
> without having to install the X Window System.
> Source and binaries are available here:
>    http://www.tigress.co.uk/rmy/zaurus/QTDRIVER/index.html
Note that it probably is nice if you indictate the status on the
webpages, too:
	QTDRIVER is Free Software under GNU GPL.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20030728/fe86049c/attachment.bin
