[GRASSLIST:302] Re: Ghostscript errors and printing site icons
Radim Blazek
blazek at itc.it
Fri Jun 6 03:27:44 EDT 2003
On Thursday 05 June 2003 22:07, Antonios Christofides wrote:
> Hi, I tried to use the 'epsfile' ps.map command to specify the icon to
> use for certain sites. However, it appears that the resulting postscript
> file is illegal:
> Error: /undefined in
> Operand stack:
> language
> Execution stack:
> %interp_exit .runexec2 --nostringval-- --nostringval--
> --nostringval-- 2 %stopped_push --nostringval-- --nostringval--
> --nostringval-- false 1 %stopped_push 1 3 %oparray_pop 1 3
> %oparray_pop --nostringval-- 1 3 %oparray_pop 1 3
> %oparray_pop .runexec2 --nostringval-- --nostringval--
> --nostringval-- Dictionary stack:
> --dict:1058/1123(ro)(G)-- --dict:0/20(G)-- --dict:122/200(L)--
> --dict:122/200(L)-- Current allocation mode is local
> GNU Ghostscript 7.07: Unrecoverable error, exit code 1
> (Same errors with gs 6.53.)
> 1) You think this could be a ps.map bug, or am I probably doing
> something wrong? The eps file appears to be legal (I created it with
> GIMP and it appears OK in ghostview).
Yes, may be bug in ps.map, but is your eps realy eps?
Does it start "%!PS-Adobe-2.0 EPSF-1.2" or similarly?
ps.map should report error if not, but better to check.
How did you save eps from GIMP, I see only "Save as" -> Postscript
(Postscript is not EPS).
GIMP is raster editor (or it was, AFAIK), I think that vectors
are better for icons (until you want to place photos in the map).
Try to make your icons in xfig.
> 2) If you are not using epsfile, how do you draw sites on your maps? The
> problem is that with 'icon' all sites are drawn with the same icon.
> Do you put each site type in a different map, although they may be
> related? Or do you use some type of raster?
Radim
PS: To draw points specified by SQL condition in ps.map/5.1:
vpoints mypoints
where name='Liptakov'
symbol basic/circle
size 20
fcolor red
end
