[GRASSLIST:315] Solved: Ghostscript errors and printing site icons
Antonios Christofides
A.Christofides at itia.ntua.gr
Sun Jun 8 06:29:36 EDT 2003
Radim Blazek wrote:
> On Thursday 05 June 2003 22:07, Antonios Christofides wrote:
> > Hi, I tried to use the 'epsfile' ps.map command to specify the icon to
> > use for certain sites. However, it appears that the resulting postscript
> > file is illegal
> Yes, may be bug in ps.map, but is your eps realy eps?
> Does it start "%!PS-Adobe-2.0 EPSF-1.2" or similarly?
Thanks, Radim, that was the problem. When you select Postscript in GIMP,
it gives you a dialog with additional options, one of those being
whether you want EPS. If you select it, the resulting file does have a
correct header, but is otherwise identical to the postscript file
created if you don't select the EPS option. Probably a GIMP bug.
With xfig there is no problem.
