[GRASSLIST:339] Re: importing vector e00
    Xueming Wu
    xwu at cse.unl.edu
    Tue Jun 10 13:23:31 EDT 2003
Actually the categories have been imported. If you change directory
to your mapset and look into sub-directory of "dig_cats", you will
find some files whose name is the name of your e00 file and using
the name of category as its suffix. You can copy a file which has
the category you want to the name of e00 file and run "r.support".
Then your Grass vector will have category.
Good Luck
Xueming
On 10 Jun 2003, Ulrich Leopold wrote:
> Dear all,
> I tried to import a vector e00 file including categories in GRASS-5.0.2.
> I used m.in.e00 but the categories are not imported.
> Any hints for better import?
> Ulrich
> __________________________________________________
> Ulrich Leopold MSc.
> Department of Physical Geography
> Institute for Biodiversity and Ecosystem Dynamics
> Faculty of Science
> University of Amsterdam
> Nieuwe Achtergracht 166
> NL-1018WV Amsterdam
> Phone: +31-(0)20-525-7456 (7451 Secretary)
> Fax:   +31-(0)20-525-7431
> Email: uleopold at science.uva.nl
> http://www.frw.uva.nl/soil/Welcome.html
> Check us also out at:
> Netherlands Centre for Geo-ecological Research
> http://www.frw.uva.nl/icg
