[GRASSLIST:346] Re: ps.map sites size_att
    Moritz Lennert
    mlennert at club.worldonline.be
    Wed Jun 11 03:25:05 EDT 2003
Radim Blazek said:
> On Tuesday 10 June 2003 18:19, Moritz Lennert wrote:
>> Radim (or others),
>> I am trying to use eps files with triangles as site icons in ps.map with
>> the size_att command. Do I understand correctly that size_att works in
>> proportion to the number of pixels in the eps file ?
> EPS is scaled by size_att, I think. If the original size of icon is 5mm
> and
> size_att 2, the size of icon in output map should be 10mm.
So that means the height of th triangle, or the length of its sides, will
be multiplied ?
Moritz
