[GRASSLIST:351] Re: ps.map sites size_att
Radim Blazek
blazek at itc.it
Wed Jun 11 08:24:27 EDT 2003
On Wednesday 11 June 2003 09:25, Moritz Lennert wrote:
> Radim Blazek said:
> > On Tuesday 10 June 2003 18:19, Moritz Lennert wrote:
> >> Radim (or others),
> >> I am trying to use eps files with triangles as site icons in ps.map with
> >> the size_att command. Do I understand correctly that size_att works in
> >> proportion to the number of pixels in the eps file ?
> > EPS is scaled by size_att, I think. If the original size of icon is 5mm
> > and
> > size_att 2, the size of icon in output map should be 10mm.
> So that means the height of th triangle, or the length of its sides, will
> be multiplied ?
Yes, but multiplied by 'size * size_att' to be precise, I hope.
Radim
