[GRASSLIST:458] Re: Getting a file from Adobe Illustrator toGRASS
Moritz Lennert mlennert at club.worldonline.be
Sun Jun 22 05:14:43 EDT 2003
Kurt Springs said:
> Hi folks,
> Well I tried all the suggestions.  I put a break in the closed polygon of
> the hill top and created a .DXF.  I used map publisher to create .e00,
> .shp,
> and .mif files.  All of these produced a file, but when I went to view it
> in
> the monitor, it was blank.  I am going to try to use v.digit.  I'll let
> you
> know how it works.
Are you sure your region settings are correct when you try to view your map ?
Try g.region rast=YourRasterMap or g.region vect=YourVectorMap, followed
by d.erase and then redisplay your map.
See http://grass.itc.it/gdp/grass5tutor/HTML/c530.html for more info about
the region.
Moritz
