[GRASSLIST:460] Re: importing shp file
Ramin Safa
raminsafa at yahoo.com
Sun Jun 22 22:16:55 EDT 2003
hi HELP
thanks for your answer but
i tried again to import but i can't do this.
my file is Arcviw shap ,countur line map,river ,..
GRASS 5.0.0,in red hat system
answer is:
HELPGRASS:~/grassdata/ZARGEH > v.in.shape -l river.shp
out=river
WARNING: Log file not specified. Sending messages to
'standard error'
Segmentation fault
GRASS:~/grassdata/ZARGEH > v.in.shape river.shp out=river
'standard error'
Segmentation fault
i need to continue,but how?
Ramin S.
> > I have trouble importing an Arcview shapefile.
> > when i use ,< v,in.shape -1 ...>the answer is :
> > Log file not specified .sending message to 'standard
> error' segment fault.
> > what is log file? how can i solved this problem and
> continue?
> > Ramin Safamanesh
> The log file is not the problem. The message just tells
> you that it will
> send all messages to standard error, which is probably
> just your screen.
> However, the problem is the segmentation fault.
> Could you tell us what version of GRASS you are using, on
> what kind of
> system (GNU/Linux, UNIX, Cygwin,...) ?
> Moritz
Ramin Safamanesh
Department of Environment Science , UPM
Email : rsafamanesh at hotmail.com Tel : 0060122399448
__________________________________
Do you Yahoo!?
SBC Yahoo! DSL - Now only $29.95 per month!
http://sbc.yahoo.com
